9Attach the Battery Holder
Pull the insulation off the end of the wires. You should see a cut in the insulation, pull from there to expose wires.
Wrap the red wire on the battery holder around the other leg of the resistor. Then fold in half to secure. Wrap the black wire of the battery holder around the short leg of the LED. Bend in half to secure. (Optional step is to cut off excess wire with wire cutters)
