Cool Can on Command
02/16/2023 at 22:28 • 0 commentsI've added a can dispenser to Astro's arsenal.
Here's the internal operation in action:
For more details, go to instructables.
Things I've Learned
02/14/2023 at 16:41 • 0 commentsAstro, after docking on the charger and sitting for a couple of minutes, may decide that the charge connection is not ideal. When that occurs, Astro will leave the charger and dock again. This takes less than a minute, but devices such as "Snacky" cannot depend upon Astro leaving the charger for 45 seconds as proof that a snack has been delivered.
If Astro loses the WiFi connection it can still navigate, find the charger or just "hang out."
Location, Location, Location
02/05/2023 at 20:09 • 0 commentsAstro has to locate the charger and back in with reasonable precision. I wondered about other locations.
I sent Astro from the charger to a spot that I named "speaker," then marked the arrival location with painter's tape.
Next, from three random locations I sent Astro to "speaker."
These arrivals are in the vicinity, but not too predictable. Next, I placed obstacles near (but not obstructing) the arrival zone.
This (very limited) test seems to indicate that a reliable landing spot can be defined for auxiliary devices to operate on Astro's load bay.
