not quite bare minimum sketch to get tubes running. has code in for real time clock and also how i handle various levels of brightness using the blanking pin on the shift register driver chips. the code is a bit rough but should be simple enough to follow :) it also does not incorporate any code to preheat elements (good for making the display appear more responsive)
