ESP32S3 module testing
05/21/2024 at 08:41 • 0 commentsAll prototype modules are 95% assembled (I don't have all the details).
Today I will tell you about the ESP32S3 CPU module:- ESP32S3 is flashed and debugged via USB-C. No debuggers and USB-UART are needed.
- RGB-LEDs are working. The implementation of the WS2812 chip protocol is hardware-based, using SPI or RMT. Everything is already included in the ESP-IDF and works great.
- The green LED 0603 (powered by 3.3V) is too dim.
- DC-DC based on TPS563201DDCR works well, but needs to be tested at currents up to 1.5-2 A.
- Intermodule connectors are convenient. Connect-disconnect quite easily, do not bend when removed. The only thing is that the pins are too long. I will shorten it in the prototypes.
Prototype testing started
05/06/2024 at 07:42 • 0 commentsnext.module prototype testing started!
PCBs for prototypes
04/25/2024 at 18:54 • 0 comments![]()
Debug modules: DBG LED
04/16/2024 at 16:20 • 0 commentsA very simple and cheap debugging module with 32 LEDs displaying the status of the pins on the intermodule interface and the presence of supply voltages
Audio modules: AUDIO OUT
04/16/2024 at 16:18 • 0 commentsModule with DAC for stereo audio output to 3.5" analog jack
RTC modules: RTC PCF8563
04/16/2024 at 16:14 • 0 commentsModule with RTC, battery and EEPROM
PSU modules: Multiple PSU modules in one device
04/04/2024 at 19:09 • 0 commentsThis schematic diagram explains how multiple PSU modules are connected in one device
PSU modules: PSU AC
04/04/2024 at 19:05 • 0 commentsThis module allows you to power your device with AC power source.
A wide range of input voltages allows this module to be used with 115V or 230V power outlets.
PSU modules: PSU DC
04/04/2024 at 18:53 • 0 commentsThis module allows you to power your device using a common DC power source.
The input voltage range is from 7 to 40 V.
IO modules: DIO16
03/25/2024 at 10:37 • 0 commentsDIO16 module is a simple 16-channel GPIO expander on I2C bus.
Logic levels - 3.3V
LED status indicators for each input/output
ESD protection
Up to 16 such modules can be connected to one device with a total number of GPIOs - 256 pcs![]()
