stepper1test.ino
This is the Arduino source file. You can enable a serial debug terminal by uncommenting the #define
ino - 17.77 kB - 12/25/2016 at 12:27
Download
gear for vacuum bar.stl
Standard Tesselated Geometry - 896.37 kB - 12/25/2016 at 12:21
Download
baseplate.stl
Standard Tesselated Geometry - 694.01 kB - 12/25/2016 at 12:21
Download
moving plate.stl
Standard Tesselated Geometry - 496.79 kB - 12/25/2016 at 12:21
Download
stepper motor holder.skp
SSEYO Koan Play File - 171.75 kB - 12/25/2016 at 12:21
Download
bearing holder for 6mm drive belt.skp
SSEYO Koan Play File - 191.62 kB - 12/25/2016 at 12:21
Download
sidecoverfront.stl
Standard Tesselated Geometry - 195.11 kB - 12/25/2016 at 12:21
Download
seed holder tria.skp
SSEYO Koan Play File - 162.37 kB - 12/25/2016 at 12:21
Download
front panel plate.skp
SSEYO Koan Play File - 194.90 kB - 12/25/2016 at 12:21
Download
sidecover1.stl
Standard Tesselated Geometry - 76.75 kB - 12/25/2016 at 12:21
Download
back panel plate.skp
SSEYO Koan Play File - 170.62 kB - 12/25/2016 at 12:20
Download
gear for vacuum bar2.stl
Standard Tesselated Geometry - 851.52 kB - 12/25/2016 at 12:20
Download
pulley bearing for 13mm bearing.skp
SSEYO Koan Play File - 188.23 kB - 12/25/2016 at 12:20
Download
bearing holder for 6mm drive belt top side.skp
SSEYO Koan Play File - 189.99 kB - 12/25/2016 at 12:20
Download
back panel plate.stl
Standard Tesselated Geometry - 61.85 kB - 12/25/2016 at 12:20
Download
front panel plate.dxf
AutoCAD DXF - 40.09 kB - 12/25/2016 at 12:20
Download
belt holder for main plate.stl
Standard Tesselated Geometry - 211.65 kB - 12/25/2016 at 12:20
Download
stepper motor holder.dxf
AutoCAD DXF - 44.86 kB - 12/25/2016 at 12:20
Download
belt holder for main plate.skp
SSEYO Koan Play File - 221.14 kB - 12/25/2016 at 12:20
Download
stepper motor holder.stl
Standard Tesselated Geometry - 46.68 kB - 12/25/2016 at 12:20
Download
front panel plate.stl
Standard Tesselated Geometry - 41.39 kB - 12/25/2016 at 12:20
Download
horizontal joiner plate.skp
SSEYO Koan Play File - 188.33 kB - 12/25/2016 at 12:20
Download
bearing holder for 6mm drive belt.stl
Standard Tesselated Geometry - 141.43 kB - 12/25/2016 at 12:20
Download
bearing holder for 6mm drive belt top side.stl
Standard Tesselated Geometry - 140.05 kB - 12/25/2016 at 12:20
Download
vacuum side vertical panel.skp
SSEYO Koan Play File - 181.93 kB - 12/25/2016 at 12:20
Download
back panel plate.dxf
AutoCAD DXF - 66.45 kB - 12/25/2016 at 12:20
Download
pulley bearing for 13mm bearing.stl
Standard Tesselated Geometry - 97.86 kB - 12/25/2016 at 12:20
Download
top moving plate.dxf
AutoCAD DXF - 45.83 kB - 12/25/2016 at 12:20
Download
seed holder tria.stl
Standard Tesselated Geometry - 25.59 kB - 12/25/2016 at 12:20
Download
horizontal joiner plate.stl
Standard Tesselated Geometry - 139.84 kB - 12/25/2016 at 12:20
Download
vacuum side vertical panel.stl
Standard Tesselated Geometry - 88.84 kB - 12/25/2016 at 12:20
Download
top holder plate belt side.skp
SSEYO Koan Play File - 190.32 kB - 12/25/2016 at 12:20
Download
vacuum side vertical panel.dxf
AutoCAD DXF - 96.06 kB - 12/25/2016 at 12:20
Download
pulley bearing for 13mm bearing 6.75mm radius.stl
Standard Tesselated Geometry - 106.35 kB - 12/25/2016 at 12:20
Download
vacuum nozzle.stl
Standard Tesselated Geometry - 185.32 kB - 12/25/2016 at 12:20
Download
horizontal joiner plate.dxf
AutoCAD DXF - 127.54 kB - 12/25/2016 at 12:20
Download
endstop holder x axis.skp
SSEYO Koan Play File - 174.84 kB - 12/25/2016 at 12:20
Download
top moving plate.skp
SSEYO Koan Play File - 170.42 kB - 12/25/2016 at 12:19
Download
belt side vertical panel.skp
SSEYO Koan Play File - 185.81 kB - 12/25/2016 at 12:19
Download
top holder plate belt side.stl
Standard Tesselated Geometry - 154.67 kB - 12/25/2016 at 12:19
Download
belt side vertical panel.stl
Standard Tesselated Geometry - 107.53 kB - 12/25/2016 at 12:19
Download
belt side vertica panel.dxf
AutoCAD DXF - 103.29 kB - 12/25/2016 at 12:19
Download
vacuum nozzle.skp
SSEYO Koan Play File - 206.95 kB - 12/25/2016 at 12:19
Download
gear for vacuum bar2.skp
SSEYO Koan Play File - 350.30 kB - 12/25/2016 at 12:19
Download
seed fall tube 5x.stl
Standard Tesselated Geometry - 458.50 kB - 12/25/2016 at 12:19
Download
top hoder plate vacuum side.stl
Standard Tesselated Geometry - 204.32 kB - 12/25/2016 at 12:19
Download
gear for vacuum bar.skp
SSEYO Koan Play File - 373.54 kB - 12/25/2016 at 12:19
Download
top moving plate.stl
Standard Tesselated Geometry - 43.97 kB - 12/25/2016 at 12:19
Download
seed fall tube 5x.skp
SSEYO Koan Play File - 304.46 kB - 12/25/2016 at 12:19
Download
top holder plate vacuum side.skp
SSEYO Koan Play File - 204.02 kB - 12/25/2016 at 12:19
Download
vacuum encap.skp
SSEYO Koan Play File - 172.86 kB - 12/25/2016 at 12:19
Download
endstop rotating axis stopper.skp
SSEYO Koan Play File - 177.98 kB - 12/25/2016 at 12:19
Download
endstop holder rotating axist.skp
SSEYO Koan Play File - 174.71 kB - 12/25/2016 at 12:19
Download
endstop rotating axis stopper.stl
Standard Tesselated Geometry - 68.40 kB - 12/25/2016 at 12:19
Download
endstop holder rotating axis.stl
Standard Tesselated Geometry - 28.64 kB - 12/25/2016 at 12:19
Download
seed holder tray left side.stl
Standard Tesselated Geometry - 25.17 kB - 12/25/2016 at 12:19
Download
endstop holder x axis.stl
Standard Tesselated Geometry - 47.15 kB - 12/25/2016 at 12:19
Download
