I am currently working on an improved baseplate, which can be either machined from plastic or be 3D printed. Since tapping M2.5 threads in plastic is pretty pointless, I will replace them with either heat-set or press-fit threaded inserts. The PCBs will need to change slightly as well, specifically the keep-out zone on the bottom layer. I took this opportunity to improve a number of things in the existing modules.
