So, I recently added a little PC just for communication, connected to the arduinos and the logic analyzer. And reachable via remote desktop. The following picture shows you the bottom of the system:
There you see the memory, the new communication PC and the clock. The yellow marked part is a poti connected to the arduino which is responsible for the clock generation to change the speed of the system.
