Because I had to realize that using the output ports as inputs works at first glance, but causes problems on closer inspection (clearing the output register is no longer possible, because an active input may keep the holding voltage at “1”), I built a 16-port input register instead—essentially just relay-implemented switched inputs onto the data bus.
Peter
