Project log -17122022
A project log for New open source hardware 1U satellite project.
tranvinhquangTRAN.VINH.QUANG • 02/26/2023 at 03:59•0 Comments
The project continues to design the UART part for the monitoring module, each chip has 16 channels, corresponding to the design that can be connected to 16 nodes, the design of the schematic diagram of node 8 done, the connections to the Nifgo development board are done.
The next work will start to design the trace for actual testing.
