Hackaday.io Hackaday.io
Sign up Log in
Generic Node (Sensor Edition)
Generic Node is an easy-to-use multi-sensor LoRaWAN® sensor node powered by STM32WL5x - ULP multi-modulation wireless s microcontroller.
makertronika-labsMakertronika Labs
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
2.1k views
0 comments
24 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 4
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
2.1k
0
24
22
Team (1)
  • makertronika-labsMakertronika Labs
Join this project's team
  • Generic Node Sensor Edition (GNSE)
  • Docs page
completed project
hardware
lorawan ulp sensor wireless lora stm32wl
Related lists
Lora projects
Lora projects
This project is submitted for
  • 2023 Low Power Challenge
This project was created on 02/27/2023 and last updated 4 years ago.
Description
The Generic Node Sensor Edition contains multiple on-board components and peripherals.
Specs:
- STM32WL55CCU6 dual-core Arm Cortex®-M4/M0+ @48 MHz
- 256 Kbytes of Flash & 64 Kbytes of SRAM
- SX126x sub-GHz radio
- Power output up to +22.00 dBm
- LoRa, (G)FSK, (G)MSK, BPSK modulations
- 868 MHz & 915 MHz dual-band operation
- 2xAA battery powered node with wide input voltage range: 2.2V - 5.5V
- ATECC608A-TNGLORA pre-provisioned LoRaWAN secure element
- LIS2DH12 - ULP 3-axis accelerometer
- SHTC3 humidity and temperature sensor
- MX25R1635 16Mb SPI NOR Flash for FUOTA and data-logging
- A user button, an RGB LED, a buzzer and a user-friendly expansion and programming options.
Project Logs
Collapse
  • Batteryless operation using en Energy Harvesting module and a Lithium-Ion Capacitor (LIC)
    Makertronika Labs • 02/27/2023 at 08:28 • 0 comments
    Lithium Ion Capacitors (LICs) are a great alternative to traditional lithium ion batteries in many LPWAN applications. This LIC module which comes with a 250F LIC and a 3.3V regulated output.
    There's also a newer/better version of this harvesting module which uses AEM10941 from e-peas.
    Solar powered version has been running for more than 6 months now (over the winter) without interruption. Here's the Datacake IoT dashboard for it.
  • Deep dive into the Generic Node hardware features
    Makertronika Labs • 02/27/2023 at 08:09 • 0 comments
  • Getting started with Generic Node
    Makertronika Labs • 02/27/2023 at 08:08 • 0 comments
  • ~10 yrs of
    Makertronika Labs • 02/27/2023 at 08:06 • 0 comments
    Device is averaging ~2.4 μA in sleep mode with periodic wake-ups to sample the sensors. Otii arc tool estimates around 10 years of battery life.
View all 4 project logs
Log In/Sign up to comment
Sign up with Github
OR
Supplyframe DesignLab: 2022 Hackada…
Wireless Sensor Network Platform (WSN) , for enviromental monitoring
Project Owner Contributor
Green Detect
sergio-ghirardelliSergio Ghirardelli
ESP8266 based soil moisture sensor Wi-Fi enabled.
ESP Soil Moisture Sensor
yancanyancan
The 2017 Hackaday Prize
A smart, affordable, open-source livestock monitoring system to help combat health problems and livestock theft.
Virtual Herder
danie-conradieDanie Conradie
The 2018 Hackaday Prize
Modular sensing platform for research
SENSEation
mario-freiMario Frei
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Generic Node (Sensor Edition)", please tell us the reason.
Send message
Remove Member
