#7 3D models and assembly drawings
07/02/2023 at 13:02 • 0 commentsI've added detailed drawings as well as all models (in .par and some in .step format) to project's Github repository.
#6 New updated PCB and schematic
05/13/2023 at 20:20 • 0 commentsI've change schematixc quite a lot since last time and this should be the final version. Files are arleady uploaded. New board works great and it's very unversal - trymmers can be used to change the scale and also the integration time (needle delay) so now it can be used with different gauges.
#5 Assembled device
03/19/2023 at 22:23 • 0 commentsThe device has finnaly been assembled. Full documentation is going to be posted here some time in the near future.
#4 First prototype
03/19/2023 at 22:13 • 0 commentsFirst board is ready and working!
#3 Final Testing
03/15/2023 at 21:07 • 0 commentsGood news! Progess has been made, I tested the circuit with connected gauge and it works perfectly! I'm going to make the first PCB in a few days now so keep following.
#2 PCB layout is here!
03/08/2023 at 21:09 • 0 commentsI've finished designing first version of PCB. It's all THT on single-sided board (with some jumpers visible as top traces) for easy home fabrication. A little bit oldschool but if the prototype works there might be an SMD version in the future.
For now I need to do the final testing and make my PCB.
#1 Schematic and prototype
03/05/2023 at 12:41 • 0 commentsI'm currently finishing the schematic and the breadboard prototype works well. Making the PCB will take some time.
Szymon Bartosik
