This project was made at the request of a Woman to be presented at the company in which she works, She wanted something simple because it worked.
My design consists of a separate leds panel in 3 triangles, green, yellow, and red. These LEDs indicate the quality of your food, depending on the combination, the panel will turn on the color that indicates the quality of your food.
The construction:
Were used
90 leds being 30 of each color
1 Arduino Uno
6 chips 74hc595
3 chips 74hc195
Resistors
Many cables (many even)
I will still upload the code on GitHub to analyze
Files
This image shows all possible combinations (sorry for being in Portuguese as soon as I translate I upload)
I think you did not understand the purpose of the project, in the led panel there are the types of food (example acids, sweets) the panel shows that if you eat acid with sweet what can happen, if everything is green its ok, yellow be careful because Can do bad and red is sure to do bad
What kind of sensors are used to measure the quality of food? What are even the criteria? Taste, freshness, vitamin content? My first criterium would be taste, but that is difficult to measure and even different between various persons.
Now, looking at the pictures, this seems to be just some glorified food table, what foods (or combinations) are considered "healthy" by some authority. You know, ask 5 experts on diet and get 10 opinions :-) Perhaps it has it's value for basic educational purposes.
