PD32 V1.0 Gerbers.zipGerber files for manufacturingx-zip-compressed - 1.16 MB - 02/15/2024 at 20:23 |
PD32-schematic.pdfschematicAdobe Portable Document Format - 766.96 kB - 02/15/2024 at 20:23 |
PD32-PCB.pdfPCB layoutAdobe Portable Document Format - 682.59 kB - 02/15/2024 at 20:23 |
PD32-FRONT.jpg3D render front PCBJPEG Image - 194.45 kB - 02/15/2024 at 20:23 |
PD32-BACK.jpg3D render back PCBJPEG Image - 194.71 kB - 02/15/2024 at 20:23 |
PD32.csvsimple BOMComma-Separated Values - 5.90 kB - 02/15/2024 at 20:23 |
Keystone PC AT board bracket model 9202 -- datasheet 202-743470.pdfThe proposed PD32 board uses the Keystone model 9202 bracket to mount in the target systemhttps://www.mouser.com/ProductDetail/Keystone-Electronics/9202?qs=g5fiFmky%2Fl4bFM8ICVGfOQ%3D%3D Adobe Portable Document Format - 239.80 kB - 02/05/2024 at 14:37 |
NS_DP84412_logic-equations.txtplain - 2.14 kB - 02/03/2024 at 23:39 |
PD32-bom.zipInteractive BOM (requires browser such as Chrome)application/x-zip-compressed - 174.05 kB - 02/03/2024 at 16:29 |
rom.a32.txtBoot ROM source code in 32K assembler.plain - 19.26 kB - 03/11/2023 at 14:40 |
dram.pal.txtThe logic equations for the PAL that works with the DRAM controller.plain - 1.53 kB - 03/11/2023 at 13:38 |
lhu646.pal.txtThis pal generates all the control signals for the 74AS646 data flow latch as well as the CWAIT (for PD32) and IWAIT (for the host) syncronisation signals. The CLK signal is used to clock the data flow flip flop. The GATE signal enables the output of the 74AS646 (the direction comes from a separate ic).The IDO signal is a single status bit that the host can read to determine whether any data is left in the 74AS646 (regardless of direction) or the state of the PD32 service request flip flop. plain - 2.27 kB - 03/11/2023 at 13:38 |
646a.pal.txtThis pal generates the control clock signals for the 74LS646 transceivers.Depending on the status of the two flip flops, the pal generates the clock signal for the appropriate 74LS646. The pal also generates CWAIT (for the 32032) if either of the 74LS646's are empty on a read or full on a write. plain - 2.80 kB - 03/11/2023 at 13:38 |
dec32.pal.txtThis pal performs the decoding for the 32016 memory space. The signal 'SWAP' is used to select either EPROM or RAM at low memory. At power on or after a reset EPROM is selected at low memory. The EPROM contains the necessary bootstrap software to communicate with the host system (pc).Note: Since the interface is a fairly generic 8 bit parallel port, any system (not just the PC) can become the host for the 32016. plain - 1.90 kB - 03/11/2023 at 13:38 |
Keith
