11Step 11: Perform Electrical Connections
Perform the electrical connections according to the attached drawing: The world is mine electrical drawing_00.pdf
Consider the following instructions:
- Insert 10A fuse on positive power supply.
- Use 2.5 mm cable in power input
- Use 1.5mm cable for matrix power supply
12Step 12: Install Software on Wemos D1 Mini
Download the attached file: The_world_is_mine_05.zip
Run Arduino IDE application and configure the wemos mini board
Install the libraries called by the sketch.
Connect the programming cable to Wemos Mini.
Compile and load the software
13Step 13: Connect the 5v 10A Power Supply
14Step 14: Light on and Enjoy!!!
Press button 1 to change the animation of the map.
