1Step 1
Setup PI3 using document order:
1. Raspberry Pi 3 Wifi Access Point
2. Setup TOR PI3
3. Screen
*From here, don't forget to swap display to your 3.5 screen or you'll need to find an HDMI to plug into.
4. Plug in second Wifi USB, portable keyboard and you portable power. (portable power needs to have an output of at least 5v=2.5A)
5. connect to the open Wifi via GUI
6. check TOR is running via command: sudo service TOR status
7. If all is good, connect your laptop or portable device.
8. check connection is running through TOR via: check.torproject.org
9. If all checks out your good to surf anonymously
***the traffic going through the PI GUI or traffic through the CAT5 will not be routed through the TOR. The only traffic routed through the TOR, is the wifi nework traffic from wlan1 throught wlan0
10. if you dont want to use the PI3 as a TOR AP, you have your power pack and portable keyboard, Mini PC!
