The microwave serves as a container of a clue in an Escape Room. This clue
should be located on the turntable. The microwave is locked during the game and can be opened by entering a correct key sequence via the touch control panel.
In the context of this Escape Room, the puzzle of the microwave builds on
the puzzle of a knife block: the sounds emitted by the knife block are to be matched with
the touch keys of the microwave - in this way the correct sequence of keys is to be discovered by one of the players.
Details
Components
1×
Sharp Microwave Silver R270 S/SLM
Artifact
1×
LM2596S DC-DC Step-Down Voltage regulator
So that one power supply for the entire circuit can be used. Arduino and Raspberry Pi need 5V, whereas the Solenoid needs 12V.
1×
12V power supply DC, 2A
Power supply for all Electronics
1×
Raspberry Pi 4 Model B (4GB)
Communication with the Game-Master via MQTT and the reception of of touch signals, Serial communication with the Arduino UNO
1×
TXS0108E Logic Level Converter
Control of the display (3.3V) with the 5V logic from the Arduino (5V to 3.3V)
