• The Past and the Future
    tinu • 01/04/2017 at 16:05 • 0 comments
    The current firmware is written in C, compiling it optimized for size leads to a 902 byte binary. It uses 20 different characters from the LCD which adds another 100 byte of data. The total size is thus 1002 bytes.
    I could reduce the size of the binary by using a custom startup code, here and there a little optimization. But I don't think I'll get it much smaller that way.
    So I started writing a version completely in assembler. It has around 520 bytes now. But it also has a number of bugs and I got distracted a bit too often to finish it on time.
    Here is a list of features I want to add but they will probably not fit into 1kB:
    • Sleep mode: Turn off all hardware and go to sleep after a period of no activity.
    • Wake-up: A way to wake up from the sleep mode would be very nice, no? Possible options: Button, periodic checks, a low power circuit which triggers on weight changes
    • Serial port: Sending the measurements to a computer.
    • Users: The ability to choose a user name for the measurement.
    • EEPROM: Store one or more previous measurements and maybe show a trend.
    • Calibration: A way to calibrate the scale, either using display and buttons or over the serial port.
    • Tara: A button or serial command to set the scale to zero.
    I hope I find time to implement a few of these ideas.
