PYPRCA - Python Programmable Calculator (computer)
DIY extremely simple pocket computer
Based on Raspberry Pi PICO+LCD+Buttons
Software in circuitpython
Public Chat
Starting from
has orders / reviews
Ships from
Universal programmable device (computer) in pocket calculator style
Is prefect for learning programming and improve build/soldering skills.
Minimum parts make it ideal for learn to solder.
Some SMD parts are little harder to place for beginners but is possible
make semi populated boards ....
There is numerical block for better native enter numbers
and QWERTY block for write programs
Instead of searching 2nd,3th colorful symbols on chaotic ABCD keyboard you can type SIN,COS etc.... on well known QWERTY keyboard
Your formulas are send to REPL for execution
It is not only calculator, it is complete
standalone python computer with python firmware
and multiple selectable apps on startup.
Hardware features:
  • write and execute scripts on device
  • Optimized for circuitpython
  • some hardware GPIO Uart RX/TX or I2C SDA/SCL
  • SD card storage
  • beeper
  • interactive REPL
  • IPS 2.8" COLOR LCD
  • 49+1 tactile soft press keyboard in matrix 7x7
  • no 3D prints = durable PCB enclosure
Working software features:
  • Boot menu
  • Text Editor
  • Photoframe
  • Turtle graphics programming
  • Plot graph
  • play mp3
  • Retro computer emulation on separated firmwares
    already working emulation ZX128, ZX48, ZX81, C64, Atari800
TODO software features:
  • text/ebook viewer
  • longer text editor
STEM Learning:
What you can learn on this board?
  • assembly and soldering skills, you need just solder one Raspberry pi PICO module and 50 switches, display soldering need some skills but I selected one with low count wires
  • circuitpython or micropython
  • Arduino programming
  • C programming
  • QWERTY keyboard matrix reading
  • complex input/output HID processing read keyboard data,
  • create and display graphics
  • save and processing files
  • work with I2C sensors or process GPS data
  • RTC clock and alarms
  • With Raspberry Pi PICO W play with WiFi and bluetooth
  • Testing if is possible to use ESP32s3 on pico pinout compatible module
  • power management, sleep, wake by alarm, wake on receive
Production and marketing plans:
Hardware is very simple and easy to solder by hand, low active component count make it very attractive as learn to solder kit.
Plan is produce partially assembled kits with already soldered display, and DIY soldering switches.
Why TH tactile switches? because is very important to precise align with front cover plate and this can be little hard with hand.
Raspberry Pi PICO Advantages:
  • Unbrickable ROM bootloader
  • Drang&drop initial setup
  • Easy soldering
  • integrated power supply
  • onboard USB connector
  • testpoints for connect USB-A for as USB host
  • effective buck/boost powering
  • use Pico W with wireless without changes
  • Waveshare alternative Rp2040plus have lion charging + USB-C and double flash memory
  • Circuitpython with libraries for almost everything with tutorials and examples
SWOT analysis
Strengths:
  • no competition with working pocket computer
  • compact encapsulated design
  • QWERTY keyboard, much user friendly than ABCD
  • officially supported Raspberry Pi PICO standard unmodified circuitpython
  • extremely simple just one easy solder module and buttons, cheap and low component count
  • low power consumption
  • native circuitpython apps, no monster OS behind
  • multiple apps on device and boot menu
  • GPIO for external sensors readings etc in school lab.
  • large 2.8"" all angles views IPS color graphics display 320x240
Weaknesses:
  • no community, no users
  • my programming knowledge is limited (I quickly learning)
  • display soldering need little more skills (semi-assembled kit may can help)
Opportunities:
  • with good manufacturing plan it ca be very good education toy
Threats:
  • I haven't caught competition in this segment, but if it appears with good marketing and a production plan may kill this simple idea
  • as everywhere, the main competition are touch screens and mobile phones
PYPRCA vs Numworsk
CircuitPythonDemoFiles.zip
x-zip-compressed - 267.71 kB - 04/24/2023 at 21:50
Download
View all 12 components
View all 5 project logs
  • 1
    Solder PICO module
    At first solder Raspberry PICO (or compatible) module, try apply power.
  • 2
    Install Circuitpython firmware
    Download Circuit python firmware directly from https://circuitpython.org/board/raspberry_pi_pico/
    • connect to PC
    • hold BOOT button and shortly press RESET
    • free BOOT button
    • you can found new DISK drive on your computer
    • drag&drop downloaded file with uf2 extension
  • 3
    Solder LCD and related SMD parts
    Align LCD small corner columns to holes and solder FLEX cable
    Solder parts in BACKLIGHT section
View all 8 instructions
soni wrote 02/05/2025 at 19:30 • point
Ruby works too?
bobricius wrote 02/05/2025 at 19:32 • point
no
Daniel Stepp wrote 01/26/2025 at 03:56 • point
Hi, I purchased this assembled for my son to learn Python, but I have no experience with this hardware / firmware. When turned on it seems to load a ZX Spectrum emulator, which is of course not why I purchased it. So how do we write and run Python programs? Could use some direction to do that. It’s all a bit confusing for someone not familiar with these kinds of DIY devices. Otherwise, it seems solid and more user friendly than the Numworks. Thanks! Daniel
bobricius wrote 01/29/2025 at 10:03 • point
now working on software redesign, old version is on github https://github.com/bobricius/PyPrCa/blob/main/CircuitPythonDemoFiles.zip
at first you need instal circuitpython (hold button on PICO and click to reset, you get new usb drive, then copy UF2 file), something from 8 version https://adafruit-circuit-python.s3.amazonaws.com/index.html?prefix=bin/raspberry_pi_pico/en_US/ then copy to circuitpython drive demo all files from this zip. I intentionally wrote that the ability to use python is now limited, and that I recommend it as a ZX emulator. If you need help with something, do not hesitate to contact me
fdufnews wrote 04/27/2023 at 13:02 • point
You say that "the main competition are touch screens and mobile phones"
The shop you bought you display at has a variant of the display with the touchscreen option TFT HC28010-DCT it is a little more expensive but not too much. Didn't you consider using this one?
I think there is a mistake in the BOM DTS-64K seems to not exist.
There are DTS-644 or DTS-648 but these one have a square button not a round one.
7mm ones with a round button are DTS-63K
http://www.dip.com.tw/en/en-product-information/en-switch004/item/download/2504_1f511f4f5b826e90b17b1a41bfb6a3ce
bobricius wrote 04/27/2023 at 13:10 • point
yes but in this case it need create touch  "only" device, I not see sense to make hybrid touch and physical buttons. I watched on, currently I have no connector for this touch part and I have no touch driver, anyway I still love physical buttons devices, Also I want keep retro computer emulation. I will think about create touch only handheld. I am still confused with this touch and internet depended devices (smartphones phones) an I hear 10x per day (Do you have our app ????)
bobricius wrote 04/27/2023 at 13:13 • point
yes, typo, you have true it is DTS-63K
alihamzagilitoo wrote 04/24/2023 at 23:05 • point
Need help 😭 😭
fdufnews wrote 04/27/2023 at 12:45 • point
Maybe you can elaborate on this.
alihamzagilitoo wrote 05/03/2023 at 23:50 • point
Plzzz hacke teenpatti because many money invest on this game...so I am notal
fdufnews wrote 04/24/2023 at 22:26 • point
Really interesting project.
Eager to see where it goes and maybe to make one.
John Hind wrote 04/19/2023 at 11:18 • point
Adafruit have reverse-mount tactile switches which would allow this to be built on a single PCB (switch legends on the front of the board with switches soldered to the back).
bobricius wrote 04/19/2023 at 11:37 • point
interesting idea, but I am afraid if there is enough space for wiring and also som doubts if hard press not cut switch from board and last if exist with 1N switch force.
John Hind wrote 04/19/2023 at 17:28 • point
With standard PCB thickness, the switch actuator sinks flush with the PCB surface before bottoming out in the switch, so no stress on the solder pads. You can still have tracks on both sides so long as all the components fit on one side. Gives a cool techno look with tracks showing faintly under the switch legends! Some thought needed to make the display sit at the right level though.
M. Bindhammer wrote 04/17/2023 at 16:49 • point
Does it support conjugate complex solutions for equations of the second to the fourth degree?
bobricius wrote 04/18/2023 at 06:13 • point
no, currently it is only combination of text editor and internal python exec(), eval() functions + math library
zyndram wrote 04/13/2023 at 17:43 • point
why python? why not ruby, mruby, haskell etc ;-)
( and please add network, for example irda )
John Hind wrote 04/19/2023 at 11:12 • point
Does say it can use PICO-W which means WiFi and Bluetooth LE. Also I2C will allow use of the huge range of low-cost STEMMA and Qwiic breakouts for sensors (though a STEMMA-QT connector would be nice!)
zyndram wrote 05/14/2023 at 07:01 • point
network must be interoperating, for any os, any medium, irda is very simple and working. Many BT version, zee etc is not flexible
