Today we cut and assembled the MDF structure of the machine. There are a few errata to note (that I will update in the files at some point). The holes for the projector are not exactly right, we manually drilled them 6mm to the left (projectors point of view). Also the small front pannel below the door needed to be 6mm higher. (Please ignore this rubbish reporting, this is mainly notes to self ;) )
Joshua Elsdon
