All code and OpenSCAD files are GPL v3 licensed and available in the linked GitHub repository.
To build the OpenSCAD files with nice rounded corners you will need to download the roundedcube library from https://danielupshaw.com/openscad-rounded-corners/ and place it in `hardware\case\`. Otherwise you can use the `no-dependencies` branch
William Buttenham
Junzhe Guo (Sebastian)
Hendra Kusumah
jareklupinski
