The lion kingdom's wasabi battery puffed after 3 years, creating a source of dummy battery parts.
There's no way to open it without destroying the plastic. Once inside, we're greeted with 2 uninsulated cells which are very easy to short circuit.
The jackpot is the gold plated circuit board. It would cost a fortune to make that.
The object of the game is to connect B+ & P-. BC is a balancing terminal which doesn't exist in a dummy battery. B- isn't connected to the terminal.
The enclosure has tabs for aligning the board.
