The lion kingdom's wasabi battery puffed after 3 years, creating a source of dummy battery parts.
![](https://cdn.hackaday.io/images/4983261680313693245.jpg)
There's no way to open it without destroying the plastic. Once inside, we're greeted with 2 uninsulated cells which are very easy to short circuit.
![](https://cdn.hackaday.io/images/4168741680313790868.jpg)
The jackpot is the gold plated circuit board. It would cost a fortune to make that.
![](https://cdn.hackaday.io/images/5911921680313896955.jpg)
The object of the game is to connect B+ & P-. BC is a balancing terminal which doesn't exist in a dummy battery. B- isn't connected to the terminal.
![](https://cdn.hackaday.io/images/1104911680314047778.jpg)
![](https://cdn.hackaday.io/images/6114181680314047872.jpg)
The enclosure has tabs for aligning the board.
