1Sketch time and CAO
Starting from a 200L drum, I designed the whole thing in Solidworks.
2Tool used
3Cutting tubes and barrel
Thanks to excel sheet, lenght has been optimized to minimize number of losses.
Tube lenght was 6 meter long.
4Frame welding and painting
Not the best welds I ever made but I get better at it and love welding stuff.
5Grid guide
I wanted something simple without complex guide. Linear guide was the solution. Screwed to the barrel on one side and riveted on the other side.
6Cutting refractory brick
7Custom parts
Made some tube caps. It was the opportunity to test the sketch drawing under solidworks.
8Final assembly
A crank, bicycle brake cable for the grid.
Two hinges and bicycle inner tube all riveted to the door.
Happy cooking ;)
f4drj
