CNC - a numerically controlled machining tools - is typically used in industry. It is fun to use it.... but it was so much more fun to make it.
Idea was to create something, which can be easily machined and assembled. One of big advantage we had, was a local workshop, where they could cut with plasma cutter.
So goal was to create frame with material, which is either bought or cut by plasma.
Adding the green old-school-machine paint... IMHO result is awesome!
