Currently printing the parts for the Y axis. It uses 500mm HGR20 Rails and again a 1605 ballscrew.
The linear rails should arrive soon and then it is time to calibrate the software and create the first parts.
A project log for G-EDM
The G-EDM is an electrical discharge machine that supports sinker EDM, EDM engraving, EDM drilling and Wire EDM operations. #Drahterodieren
