XY Update - Parts arrived
A project log for G-EDM
The G-EDM is an electrical discharge machine that supports sinker EDM, EDM engraving, EDM drilling and Wire EDM operations. #Drahterodieren
gedm-devgedm-dev 07/21/2023 at 18:080 Comments
Just a small update.
All parts for the XY conversion arrived and I'm currently working on the technical drawings for the Aluminum parts.
The images don't show the final arrangement. The linear blocks are raised with 3D printed spacers and the ballscrew is mounted below the aluminum plate.
It uses 500mm HGR20 rails for the Y axis. The aluminum parts are 15mm thick.
