Back to overview
Multi-storage bed for our tiny apartment
The whole bed should look like this.
MDF build with 2 glasses shelves and led strip.
To support the frame, I design empty MDF feet on each corner. Probably the most complex part of the bed.
Using Dremel with abrasive head and under a trickle of water, I managed to get nice round corner and a hole for the aluminium tube.
Don't use spray paint indoors ! :)
An aluminum U is embedded in all the edges of the structure for the final touch.
Maybe little bit overkill... but that's all I found in my garage.
Here it is !
