Tools used:
Diamond engraving bit for a dremel rotary tool
Dremel rotary tool
3/8" drill bit
Electric drill
Needle nosed pliers
Xacto knife
Pencil
Bow compass, for marking out angles
Game that I plan to use this counter for:
EDH MtG
I had old hard drive platters sitting around, a bored evening, and wanted to keep track of a MtG score.... :)
Tools used:
Dremel rotary tool
3/8" drill bit
Electric drill
Needle nosed pliers
Xacto knife
Pencil
EDH MtG
My normal card game night was cancelled, so I had the evening to do something else. I was sitting there and looking at my new EDH MtG deck and thinking "I wonder if I can make a life counter out of that stack of hard drive platters over there."
This project took 1 evening, about 2 hours.
The first step was to decide what number I wanted to go up too, in my case I chose 159, this meant that the outer ring would need to be numbered from 0 to 15 and the inner ring from 0 to 9. After marking on the old hard drive platters with a pencil, I used an xacto knife to scribe the numbers in. This served two purposes, the surface is so smooth that pencil will just wipe off, and gave the rotary tool that I used something to follow. Sorry about not having a picture of this step, I didn't think to take one :(
After I marked out the layout, I sat down with my rotary tool with an engraving bit. Be sure to wear safety glasses, there will be small bits of metal flying off :)
I used the rotary tool to cut a small center point for the drill bit. If you do not do this and are using a hand drill, there is a chance that the bit will walk across the surface of the platter, permamently marring it.
