Testing the logic for a diode ROM to be used on the Brainwarp entry panel. So far so good as it is working as expected. This test panel uses 2 bit addressing to select between 4 memory addresses with 4 bits each.
A project log for The Cardboard Computer - IO is my name
My goal is a 4-bit CPU using recycled cardboard substrate and Diode Transistor Logic. This is an educational platform for me.
Just FYI... if you cut the leads shorter, the diodes will work fine and take up less space ;)
...yes, or course I'm being facetious, why do you ask? :P
