13d Printing
3d print these 3d models using Onshape:https://osd.onshape.com/documents/bce763c140e0d1f4b60caca3/w/d3b92d8cee05361d7e29aa4c/e/132df27706402643b5f49f92
2Arduino
Plug in arduino to a windows computer via usb for coding in C++
3Potentiometer and Servo
Plug potentiometer and servo into Arduino(Servo:Gnd to black, 5v to red, ~3 to yellow) (Pot: Gnd to rightermost pin, A3 to middle pin, 3v to leftmost pin) using breadboard wires.
4Download Code
- Download our code in c++:
- #include <Servo.h>
- Servo myServo;
- int potPin = A4;
- int potValue = 0;
- void setup() {
- myServo.attach(3);
- pinMode(potPin, INPUT);
- myServo.write(0);
- Serial.begin(9600);
- void loop() {
- potValue = analogRead(A4);
- Serial.println(potValue);
- if((potValue < 679) && (potValue > 452)){
- myServo.write(180);
- else if((potValue < 452) && (potValue > 225)){
- myServo.writeMicroseconds(1500);
- else if((potValue < 225) && (potValue > 0)){
- myServo.write(-180);
5Attach 3d Printed Gears
Glue gears to servo
6Attach 3d Printed Parts
Glue the two 3d printed parts together
7Apply Spectrum
Apply (tape) spectrum to the 3d printed parts
8Attach Servo to 3d Parts
Slide the back end of the servo onto the bracket
9Slide Servo Into Place
Slide bracket onto the lip of the spectrum
