- Got the formula down for the python code, just need to do a lot of coding to add in all the months and dates, etc.
- Continued researching for the light aspect
- Tried running the python code, but it was flawed, still checking. Eventually got it working correctly.
- Finished the python code! It can now correctly recognize dates, and compare them. When we press a key, the file runs, and we want to make it run when we take a picture.
- Became stuck on finding a correct light.
- Got the camera to work
- Ended up still using scenetext recognition, got some errors and got stuck
- continued to work on lights, but got stuck because we could not get neo lights working, and we started using the breadboard for the LEDs
- GOT THE LEDS WORKING! They blink on and off, and we have figured them out FINALLY.
