This our setup. The camera seen nesting on the top right corner of the monitor is a Logitech C270 HD Webcam, this is the camera used for giving the computer an image for the date. On the monitor screen, our program is seen running. The program we are using is just meant to clarify the dates (ex: the date may be written in all caps, or all lowercase, which our program covers), and to assist the camera in reading dates. The jetson nano, wires, and resistors on the table are for connecting what the camera sees, along with the program to the breadboard and LEDs that will light up based on the program's output. If the date is expired, the red LED will light up, and if the date is not expired, the green LED will light up.
