1Use of Materials
Make sure that you have all of the materials and they are all working properly, they need to all be working and function well.
2Programs + Libraries
Download Arduino Uno, then you have to download all of the libraries for the NeoPixel. NeoPixel Libraries include: AdaFruit_NeoPixel, AdaFruit_Matrix, Adafruit_GFX
Make sure that the OnShape files are made and ready (from here), unless you want to make your own stand for the NeoPixels.
3Code
Write the code yourself, or copy and paste the code from this link
The code are made for things like the bunny jumping, the sprites of the bunny, the button wiring so it goes through to the program, the way that the program works so the user feels like the bunny is running, carrot sprites, many other things.
4Connections
Make sure that every pin inside of the Arduino is used correctly and setup well, certain pins reference things like the code or the button. You also have to make sure that everything works and is connected properly. Also check that the board and serial numbers are connected to the Arduino Uno.
Resistor should be connected to GND and 8
Pins should be connected to 5V, 6, and GND
5Final Touches
Check everything, no bugs in the code, make sure that everything runs properly and smoothly.
