Build Updates - 1/10/17
01/10/2017 at 12:59 • 0 commentsI went to Menards over the weekend, and picked up some polyester rope, which has almost no stretching issues. I was previously using 550 paracord, as it was all I had on hand. Additionally, I now have 3 turns of rope on each pulley, so there is plenty of friction to move the curtains.
Another upgrade was the replacement of the 9V power supply with a 12V supply. The motor I use is 12V, so it was initially underpowered. Now, it is working better than ever.
I still need to implement the hall effect sensors to eliminate the timed opening and closing.
First Run and Alexa Integration
01/03/2017 at 20:25 • 0 commentsThe curtains are up and running!
They are controllable via HTTP requests, and are integrated into our Smart Home hub (which should also be a project on here some day...).
Additionally, through emulating a Hue bridge, the curtains are controllable with voice commands and Alexa.
The code will be on GitHub soon, and I will post the models as well.
