adding switches to home assistant
A project log for Rezodo: Long Range irrigation and weather station
Rezodo aims at building a distributed irrigation system and a weather station with farmers. It's also a fully open platform for IoT learning
jp-gleyzesJP Gleyzes • 04/19/2023 at 12:56•0 Comments
"Once again we will use the power of Home Assistant to add switches to the interface and to allow these switches to publish messages with MQTT.
This is a simple process if you follow these instructions:
add an editor to home assistant
go to the add on store and select "File Editor"
install it run it
then you can click on "open Web user interface" this will magically open the file editor and the famous "YAML file" of home assistant
This file handles all teh configuration of your HA. With a new project it is almost empty.
We will add a MQTT switch in this file.
Any time we write something into this file the consistency is cheked and the gren mark on top right corner should remain green. If becoming red it is most likely an error of indentation into your YAML file.... Beware of blank space... they go usually two by two !
To add a switch copy paste these lines:
mqtt:
  switch:
    - unique_id: S1C1
      state_topic: "garden/S1/C1"
      command_topic: "garden/cmd/1/1"
      payload_on: "[{\"id\":1,\"type\":1,\"data\":1}]"
      payload_off: "[{\"id\":1,\"type\":1,\"data\":0}]"
      optimistic: true
      qos: 0
      retain: true
It tells the following:
payload to topic garden/cmd/1/1 à 14:48 :
        "id": 1,
        "type": 1,
        "data": 1
Now we can save the YAML file with these lines inserted.
We then need to restart the Home assistant (go to the developer tools, on top of the page)
And that's it you have a nice switch on your HA main page
You can test it using the MQTT add on and see that it works when you change this switch while listening to the " garden/cmd/1:1" topic
As it works for one switch we will now add the 7 missing to configure our Rezodo.
Simply copy paste these lines into the YAML
mqtt:
  switch:
    - unique_id: S1C1
      optimistic: true
      qos: 0
      retain: true
    - unique_id: S1C2
      state_topic: "garden/S1/C2"
      command_topic: "garden/cmd/1/2"
      payload_on: "[{\"id\":1,\"type\":2,\"data\":1}]"
      payload_off: "[{\"id\":1,\"type\":2,\"data\":0}]"
      optimistic: true
      qos: 0
      retain: true
    - unique_id: S1C3
      state_topic: "garden/S1/C3"
      command_topic: "garden/cmd/1/3"
      payload_on: "[{\"id\":1,\"type\":3,\"data\":1}]"
      payload_off: "[{\"id\":1,\"type\":3,\"data\":0}]"
      optimistic: true
      qos: 0
      retain: true
    - unique_id: S1C4
      state_topic: "garden/S1/C4"
      command_topic: "garden/cmd/1/4"
      payload_on: "[{\"id\":1,\"type\":4,\"data\":1}]"
      payload_off: "[{\"id\":1,\"type\":4,\"data\":0}]"
      optimistic: true
      qos: 0
      retain: true
    - unique_id: S2C1
      state_topic: "garden/S2/C1"
      command_topic: "garden/cmd/2/1"
      payload_on: "[{\"id\":2,\"type\":1,\"data\":1}]"
      payload_off: "[{\"id\":2,\"type\":1,\"data\":0}]"
      optimistic: true
      qos: 0
      retain: true
    - unique_id: S2C2
      state_topic: "garden/S2/C2"
      command_topic: "garden/cmd/2/2"
      payload_on: "[{\"id\":2,\"type\":2,\"data\":1}]"
      payload_off: "[{\"id\":2,\"type\":2,\"data\":0}]"
      optimistic: true
      qos: 0
      retain: true
    - unique_id: S2C3
      state_topic: "garden/S2/C3"
      command_topic: "garden/cmd/2/3"
      payload_on: "[{\"id\":2,\"type\":3,\"data\":1}]"
      payload_off: "[{\"id\":2,\"type\":3,\"data\":0}]"
      optimistic: true
      qos: 0
      retain: true
    - unique_id: S2C4
      state_topic: "garden/S2/C4"
      command_topic: "garden/cmd/2/4"
      payload_on: "[{\"id\":2,\"type\":4,\"data\":1}]"
      payload_off: "[{\"id\":2,\"type\":4,\"data\":0}]"
      optimistic: true
      qos: 0
      retain: true
Save it, restart the HA and go to the main page
Here it is! 8 switches which can command your Rezodo.
Well ... almost... We still need to configure our Arduino code to register to the messages we want.
Open the MQTTsubscription.h file into your FDRS libray folder and add these lines:
client.subscribe("garden/cmd/1/1");
client.subscribe("garden/cmd/1/2");
client.subscribe("garden/cmd/1/3");
client.subscribe("garden/cmd/1/4");
client.subscribe("garden/cmd/2/1");
client.subscribe("garden/cmd/2/2");
client.subscribe("garden/cmd/2/3");
client.subscribe("garden/cmd/2/4");
Save the file and recompile... Now the Rezodo will receive the command messages any time it wakes up.
Cool again !
