SUMP/OLS compatible logic analyzer firmware for RP2040 boards
ula_0.0.2.uf2μLA firmware for RP2040uf2 - 48.50 kB - 04/15/2023 at 07:03 |
Hey Fred!
Thank you for your feedback.
Edge triggers are supported by firmware, but OLS protocol, used in Sigrok doesn't have this feature. Probably I will do a small research and switch to another protocol later.
Channel can be mapped to any 16-bit range by changing PIN_BASE constant here https://github.com/dotcypress/ula/blob/main/src/main.rs#L31
I just did a build for you, you can download it here: https://github.com/dotcypress/ula/files/11465739/ula_0.0.3_gusman.uf2.zip
Nice work!
I have 2 questions/requests:
- I don't see edge triggering; is it normal?
- could it be possible to map channels to GPIO 2 to 17, instead of 0 to 15? This way, it could be possible to use gusmanb hardware without loosing the first 2 channels, as gusman hardware uses GPIO 0 and 1 for triggering purposes...
Thanks!
Does this only work for 3.3V logic levels or is it also possible to connect the GPIO pins directly to 5V logic? I have seen different views on the 5V tolerance of the Pi Pico's GPIOs so I am unsure if level shifters might be needed.
