Assembling_You_WizFi_Trundlebot.pdf
Build instructions document when using the WIZnet - WizFi360-EVB-Pico.
Adobe Portable Document Format -
2.66 MB -
04/19/2023 at 15:02
Preview
Trundlebot_Trundlepad0.stl
The "Trudlepad" for the front of the Trundlebot. 3D print one of these.
Standard Tesselated Geometry -
1.13 MB -
04/19/2023 at 15:02
Download
Trundlebot_PCB_Layout.pdf
A diagram of the PCB layout.
94.68 kB -
04/19/2023 at 15:02
Preview
Trundlebot_Motor_Holder0.stl
The housing for the motos. 3D print two of these.
214.93 kB -
04/19/2023 at 15:02
Download
Trundlebot.kicad_pcb
The KiCAD file for having your own circuit board manufactured.
kicad_pcb -
156.62 kB -
04/19/2023 at 15:02
Download
Trundlebot_Bowerbank_Holder.stl
A holder for a power bank. Optional if you don't want to have the Trundlebot tethered by a USB cable. 3D print one of these.
233.48 kB -
04/19/2023 at 15:02
Download
Trundlebot_Chassis.dxf
The main chasses of the Trundlebot. Laser cut one if these of you can. Make one out of anything if you can not. Thick cardboard will work.
AutoCAD DXF -
33.36 kB -
04/19/2023 at 15:02
Download
Trundlebot IO Mapping.pdf
What pin is connected to what port for the more advanced programmer.
24.20 kB -
04/19/2023 at 15:02
Preview
Trundlebot_Schematic.pdf
A schematic of the circuit board.
114.02 kB -
04/19/2023 at 15:02
Preview
Trundlebot PCB Layout.pdf
The component layout of the PCB.
94.68 kB -
04/19/2023 at 15:02
Preview
Trundlebot_bom.csv
The bill of materials for online manufacturing.
Comma-Separated Values -
3.06 kB -
04/19/2023 at 15:02
Download
