any help or recommended ideas would help and appreciate thanks
Really depends on what you need. If you need proper bluetooth I'd use the 32. For basic IOT WIFI stuff the 8266 is fine. If you need a little more grunt you can even go for the Pico W. What sort of project are you looking for?
Yes, delete it Cancel
You are about to report the project "ESP32 OR ESP8266?", please tell us the reason.
