Added the momentum parameter to the network (not as an option though, will mayb do that if it has undesirable effects)
but adding momentum hasnt helped the XOR problem still , now i think i need help solving the XOR problem because i wont be able to sleep peacefully without making a perfectly working library so
Please HELP !!
