1Create a Discord server
To create a Discord server, you need to open the Discord application, log in to your account, click on the "+" button, select "Create a Server", choose a name and icon, create any roles you need, create channels based on your needs, and then invite people to join your server.
2Create a Discord bot account
Start by creating a new bot account in the Discord Developer Portal. After you've created the account, make sure to keep track of the bot token. You'll need this token later on to authenticate your bot.
3Set up your Raspberry Pi
Set up your Raspberry Pi Zero 2 by using the Raspberry Pi Imager for MacOS to configure your internet network, and enable SSH with the user pi and the password pi, then install Raspberry Pi OS Lite to run headless.
4Install the necessary dependencies
Install pip. Install the following libraries using pip in your command prompt or terminal. The
discord.pylibrary is used for interacting with the Discord API. Theopenailibrary is the official Python client for the OpenAI API (GPT-3). -
5Write your bot's code
Open your preferred text editor and create a new Python file. At the beginning of the file, import the "discord" and "commands" modules from the discord.py library, along with "asyncio," "requests," and "psutil." The code will implement a Discord bot that uses OpenAI's GPT-3.5-turbo model to respond to user messages and automatically summarizes chat conversations after 5 minutes of inactivity. Set up integration with OpenAI's GPT-3.5-turbo model by defining the
API_KEYandAPI_URLvariables, which contain the API key and URL for the GPT-3.5-turbo API, respectively. Define theheadersdictionary for API requests, which includes the "Content-Type" and "Authorization" headers. Define thechat_gpt_requestfunction to send requests to the GPT-3.5-turbo API, passing the input data and headers, and to return the response from the model. Create thechannel_messagesdictionary to store the message threads for each channel. Initialize the bot with the appropriate intents, and define thecurrent_timer_taskvariable to store the current timer task. Define theon_readyevent to execute when the bot is ready. It sends a message to a specific channel with information about the bot's memory usage and free space. Thegptcommand is defined to handle user input from Discord. When the command is invoked, the bot sends the user's input to the GPT-3.5-turbo model and responds with the model's output. Thetimer_taskcoroutine is defined to summarize the chat conversation after 5 minutes of inactivity. It sends a request to the GPT-3.5-turbo model to summarize the chat and replaces the chat with the summary. Finally, start the bot with your provided token. -
6Automatically launch the bot on startup
Set up your Raspberry Pi Zero 2 to have your Discord bot run continuously, and
systemdwill automatically restart the bot if it crashes or if the system reboots. -
7Modify a paper mache skull to hold the Raspberry Pi Zero 2
Take a paper mache skull and, using a sharp blade, carefully cut out a rectangle big enough to fit the Raspberry Pi Zero 2. Insert the Raspberry Pi with its power cord into the paper mache skull.
Mx. Jack Nelson
