1Structure your directory
Set up a directory structure on your local computer that looks like this:
SpinLast/
├── getSessionKey.py
├── SpinLast.py
└── static/
├── styles.css
└── templates/
├── index.html
└── submit.html -
2Get a Last.fm API account
Sign up for a Last.fm API account and record your Last.fm API Key and Shared Secret somewhere safe.
3Edit getSessionKey.py
Edit the getSessionKey.py file to include your API Key and Shared Secret.
4Acquire your Last.fm Session Key
From the command line, navigate to the SpinLast directory and run getSessionKey.py and follow it's instructions to get your permanent Last.fm Session Key.
5Edit SpinLast.py
Edit the SpinLast.py file to include your API Key, Shared Secret, and Session Key.
6Run the SpinLast.py application
From the command line, navigate to the SpinLast directory and run the SpinLast.py application.
7Visit the self-hosted website, scrobble away!
Visit the self-hosted website at http://localhost:5000/ and submit any Spinatron URL (like https://spinitron.com/KXLU/) to start scrobbling automatically.
The application will continue running and the webpage will display the most recently scrobbled track as the Spinitron playlist plays in real time.
