The Raspberry PICO HW works out fine. By adding a 2-channel relay board, which is optically connect and directly controlled, the unit makes sense. Although the OS switch from Python to microPython had a learning curve, it was small.
Oh, the HW...
H = pre-soldered header pins
W = WiFi included
...and only $15? Heck yeah
