Solder 3 pin JST PH 2.00mm to connect the BioAmp Cable with your Muscle BioAmp BisCute.
14
I/O header pins
Solder 2.54mm header pins to interface the your BisCute to Arduino UNO/Nano or any other development board of your choice.
15
Quad OpAmp
Solder Quad OpAmp which is the heart of your Muscle BioAmp BisCute. As we are testing new ICs with each version update you may find different Quad OpAmps in the kit depending on the time you bought the kit from us.
16
BisCute baked, best served hot ;)
You are ready to use your own Muscle BioAmp BisCute EMG sensor to create cool HCI projects.
