[M] 5mm motor holders and reversed extruders
A project log for Coaxial8or [gd0144]
Full-colour FFF? Multi-materials with unparalleled interlayer bond strength? Abrasives without abrasion?
kelvinakelvinA 12/06/2024 at 14:110 Comments
These substantial looking plates are 5mm because it's the same thickness as the clamp plate and it's thicker than 3mm. If you remember all the way back to the start of the year, I had to use washers because of the DDEs (aka BMGs). Since I was planning on inverting the DDE's closest to the hotend, I thought I might as well correct my earlier error.
This is what it looked like when they were being cut out on the waterjet:
The uni only happened to have M5 x 20mm bolts, so I used the M5x5mm brass insert strategy to "shorten" the threads to M5x15mm whilst undergoing the installation:
It was much easier to install the DDEs and they feel more solid/secure. I've been able to shorten the bowdens E0, E1, E6, E7 by 5cm, down to 30, 30, 30, 35cm respectively (about 14%). Additionally, it's much more ergonomic to reach the large gears on those extruders now.
In other news, I've found a good Autodesk Fusion texture that seems to look similar to the waterjet cut edges:
