[X] SANPrinter Dual Drive Extruder can't be used in reverse
A project log for Coaxial8or [gd0144]
Full-colour FFF? Multi-materials with unparalleled interlayer bond strength? Abrasives without abrasion?
kelvinakelvinA 12/15/2024 at 15:490 Comments
This is Channel 7 (E0-7 translates to Ch1-8 respectively)
So today I did the following:
Ch 7 was the last one that I needed to do and it turned out to be the one to pop out, revealing that the input bowden coupling is merely just a friction fit. It seems like this coupling form over function; it looks nice but, as you can see, won't stick around for the long term. I never knew such a collet existed, but it could be useful if paired with a grub screw.
(Note: SANPrinter also goes by the name SANBrother)
