I've added a leak shielding to the thermistor grub screw. I've also removed some leak channels and made the remaining ones deeper in depth so that leaks:- can be detected faster
- have less "crosstalk", potentially making it harder to determine leak origin if 2 filaments are of similar colour
- don't pose a threat to the thermistor
- can more easily flow out the sides instead of squeezing through the small gap between the coaxial8or and clamp plates
kelvinA
