I've been able to improve the start gcode and figure out how to get the filament colours to display. The code...
M140 S[first_layer_bed_temperature] ; Start preheating the bed M104 S[first_layer_temperature] ; Start heating nozzle G28 ; Home G0 Z15 F1200 M190 S[first_layer_bed_temperature] ; Wait for bed to reach temp M109 S[first_layer_temperature] ; Wait for nozzle to reach temp G28 Z ; Home Z axis ; Virtual Tool Setup T0 ; Filament: [filament_preset_15] [filament_notes_15] M164 S15 ; Filament: [filament_preset_14] [filament_notes_14] M164 S14 ; Filament: [filament_preset_13] [filament_notes_13] M164 S13 ; Filament: [filament_preset_12] [filament_notes_12] M164 S12 ; Filament: [filament_preset_11] [filament_notes_11] M164 S11 ; Filament: [filament_preset_10] [filament_notes_10] M164 S10 ; Filament: [filament_preset_9] [filament_notes_9] M164 S9 ; Filament: [filament_preset_8] [filament_notes_8] M164 S8 ; Filament: [filament_preset_7] M165 O1 M164 S7 ; Filament: [filament_preset_6] M165 N1 M164 S6 ; Filament: [filament_preset_5] M165 M1 M164 S5 ; Filament: [filament_preset_4] M165 L1 M164 S4 ; Filament: [filament_preset_3] M165 D1 M164 S3 ; Filament: [filament_preset_2] M165 C1 M164 S2 ; Filament: [filament_preset_1] M165 B1 M164 S1 ; Filament: [filament_preset_0] M165 A1 M164 S0 ; Extruder Priming Setup T[current_extruder] G0 X0 Y0 Z0.5 F9000 M83 ; Extruder Relative mode G1 Y305 E48 F600 G0 X0.5 G1 Y0 E48 G1 E-2 ; Retract G92 E0 ; ;Prime Finished M204 P2400
...produces:
[...] ; Filament: cr600s.All M165 A1 B1 C1 D1 L1 M1 N1 O1 M164 S9 ; Filament: tmp.magentaBlack M165 L1 N1 M164 S8 ; Filament: petg.Transparent M165 O1 M164 S7 ; Filament: petg.Black M165 N1 M164 S6 ; Filament: petg.Copper M165 M1 M164 S5 ; Filament: petg.Magenta M165 L1 M164 S4 ; Filament: petg.TransBlue M165 D1 M164 S3 ; Filament: petg.Mint M165 C1 M164 S2 ; Filament: petg.Yellow M165 B1 M164 S1 ; Filament: petg.White M165 A1 M164 S0 ; Extruder Priming Setup T8 ; Priming nozzle G0 X0 Y0 Z0.5 F9000 M83 ; Extruder Relative mode G1 Y305 E48 F600 G0 X0.5 M73 P1 R31 G1 Y0 E48 G1 E-2 ; Retract M73 P3 R31 G92 E0 ; ;Prime Finished M204 P2400 G21 ; set units to millimeters G90 ; use absolute coordinates M83 ; use relative distances for extrusion ; Filament: tmp.magentaBlack T8 [...]
This utilises the filament_notes field to store the mixes, and uses the toolchange-gcode to make filament name comments:
; Filament: [filament_preset_[next_extruder]]
With this, PushPull should work correctly. Before, the mix was changed only after the tool was, so the first change to a new virtual tool would have an incorrect PushPull event. Additionally, a user wouldn't be able to change the mixes during the print.
Marlin feature idea - AutoMix
While my gcode changes hopefully reduce my issue list, it likely isn't sustainable for more than a handful of virtual filaments and it would be more ideal for the slicer to just tell the firmware what colour and transparency is desired. For this, it would need to know:
- AutoMix channel?
- If no, there should be a settable mix. E.g. 50% ABS channel, 45% AutoMix, 5% TPU channel = tinted ABS
- Material Colour: RGBA hex
- No I'm not expecting 16.7 million colours from the c8or.
- 4 bits per channel is already loads for FFF 3D printers: 4096 colours, 16 levels of opacity.
- Firmware will need some understanding to know "#0000" and "#FFF0" are both equivalent to "full transparency"
- Potentially a Look Up Table (LUT) for gamma
- The WhiteBlack test print is slightly darker than the midpoint "#888F" grey, seeming closer to "#666F".
- Hopefully it's as simple as printing a 1 : 1 mix of 2 materials, inputting the resultant colour and then generating a LUT curve that passes through it, similar to pressure curves for stylus tablets:
With this feature, the firmware can be the one to worry what channel white filament is in and the ratios needed to produce "#9A9F". This would also open the realm to automatic backup channels, such as loading 3 half-spools of black filament for a large print.
Understandably, the order of filaments is still important for the end result to look correct. Perhaps there should be a warning if one of the Automix colours has notably higher luminosity than a channel that's further into the extruded material.
