Finally! I've been trying to solve a solution essentially daily since the 8th and I've finally arrived at one that minimises the drawbacks and incorporates the benefits.
My ceiling for modelling was 20cm3, and the result is a respectable 17.2cm3. The PCBWay autoquoter says this print is $35.
From the top of the o-ring to the Y split is 19.5mm long uninterrupted, so I'm expecting that this heatblock can put the "ate" in Coaxial8or when it comes to consuming filament.
As for aesthetics, I think I've done a passable job with the limitations I have to abide by. Like previous designs, there's a main element of symmetry. Somewhat inspired by earbuds, I've used fillets to make everything seem more organic, like a pebble. There are also some sharp edges, a design tip I saw used for cars (and some earbuds). I like how my logo is somewhat obscured, peering out of the shadows.
[Oct 21] - I've opted to go with a sharp circle for all inputs/output. I feel it will have more pronounced deformation.
I'm also trying a new variable fillet across the bottom to improve aesthetics:
[Oct 27]
I've added a cutout so that the allen key has uninterrupted access to the bolts, requiring a slight aesthetics adjustment, and I've made use of the internal space to add a 5-way intersection so that each collection of 4 inputs can change their resultant mix relatively quickly.
I'm also testing to see if there's a step-increase in PCBWay's delivery cost if the shortest bounding box dimension is 30mm or more. The R1 and R2 orders cost sub-$8 to ship, which both were 29mm or less on an axis. R0 was 35mm at its thinnest and was around $16. R3 was 30.0mm, but I've reduced it to 29.9mm in hopes of reducing its $12 delivery fee.
