Sooo...I received the replacement parts, and this time decided that I would put one pixel and the Pico on the board, then try to get it working. At that point, I will put on the other pixels.
Well, that was the plan. The reality is...a little different.
I put one pixel on, then soldered on the Pico. I put in the cap that was supposed to be there (according to LadyAda). Then I tried some programming.
I was able to get the on-board LED to light up through code, so that was good. Then I set my sights on the Neopixel.
I soldered it on, then tried the pixel code--no light.
I got the gerber file out and followed the trace to be sure that the one I had soldered on was, in fact, the first. It was, but still no glow.
I put on the other two in that row, just in case it had been run differently somehow. No glow.
I put the last one on in case it was going the other way. No glow.
At that point, I put it away to think about what was going on.
I came back to it today with an idea--I got some wire, and soldered a pixel directly to the Pico, to the same pins that the other pixels are on. And:
So...this tells us that my understanding of the pixel (and my code) is correct. I ended with this code:
import time import board import neopixel import random num_pixels = 2 pixel_pin = board.GP18 pixels = neopixel.NeoPixel(pixel_pin, num_pixels) pixels.brightness = 0.5 rnd_r = random.randrange(0, 255) rnd_g = random.randrange(0,255) rnd_b = random.randrange(0,255) print(rnd_r) print(rnd_g) print(rnd_b) COLOR = (rnd_r, rnd_g, rnd_b) while True: pixels.fill(COLOR) pixels.show()
(The random numbers are there so that every time it runs, the color will change and I will know that the new code is running (or at least a new version of the code).)
It also tells us that the problem is between the Pico and the pixel. So that means it could be:
- a problem with the soldering of the Pico to the board.
- that the Pixel isn't fully connected to the pads on the board, though I've tried everything I can to be sure
- that, while trying to ensure the pixel is connected well, I've managed to fry it.
- a design problem with the board itself
The easiest thing to do is to use a multi-meter to check is the trace on the board. So I'll do that next.
One look at your schematic and it's obvious. Your LEDs are not powered. There's a capacitor between the positive supply rail and the power pin of the LEDs. I think you meant for those capacitors to be bypass capacitors across the power rails but they are blocking the supply into the LEDs.
Thank you for the help! You are referring to C1, C2,....C23? That makes sense. I was following advice from the NeoPixel Uberguide, but I noticed that a lot of that guide is done with costumes in mind, plugging large numbers of pixels into a car battery or something. I will try to bridge one of those caps and see what happens. Thank you!
