13D printing output
Please download the following three files uploaded to FIles and output them with a 3D printer. ABS and PLA materials are fine.
However, be careful about the material of "ank_parts.obj" if you actually want to make it drink liquid (milk). If the material is not waterproof, water leakage will occur. Also, when using warm water, be careful about the heat resistance of the material.
2PCB Board Output
Please produce the following three files in FILES
- PCB_Cryingbaby_HeadBord.zip
- PCB_Cryingbaby_MilkBord.zip
- PCB_Cryingbaby_MainBord.zip
Also, solder the components listed in the Schematic file.
takayuki.kosaka
